Feynman’s Fabulous Formula
Richard Feynman’s famous formula reveals a remarkable connection between graph theory, the Ising model, and quantum field theory, showing how a purely combinatorial problem can be expressed through elegant geometric ideas. The article explains that the formula equates two seemingly unrelated mathematical objects: a polynomial obtained by summing over all even subgraphs of a planar graph and an infinite product built from closed paths, with carefully assigned signs determined by their winding numbers.
Although the identity appears almost miraculous—especially because infinitely many terms ultimately cancel each other—it provides deep insight into why diagrammatic expansions, so central to Feynman’s work, are also fundamental in statistical physics. The post traces the history of the formula from the work of Kac and Ward on the Ising model, through Sherman’s proof, to Feynman’s influential reformulation, highlighting how ideas from physics and mathematics enriched one another.
The discussion then broadens to arbitrary finite graphs, where the original planar result is extended using sophisticated concepts from modern geometry, including spin structures and Arf invariants. This generalization demonstrates that the same underlying principles remain valid far beyond the planar case, revealing unexpected links between combinatorics, topology, geometry, and the mathematics of fermions and conformal field theory. Rather than being an isolated identity,
Feynman’s formula serves as a gateway to a rich landscape of ideas involving discrete complex analysis, Dirac operators, and Riemann surfaces. By uncovering these hidden relationships, the formula illustrates how elegant mathematical structures can unify diverse fields of research, making it an enduring example of the deep interplay between mathematics and theoretical physics.
