07-03-2026, 03:26 PM
Teardrop Curve
The teardrop curve is a fascinating family of plane curves that, as its name suggests, resembles the shape of a teardrop. It is defined by a pair of parametric equations, where a parameter controls how pointed or rounded the curve becomes. When this parameter changes, the shape smoothly transforms from a perfect circle into increasingly elongated teardrop-like forms.
In addition to its appealing appearance, the curve has well-defined mathematical properties, including an exact formula for the area it encloses expressed using the Gamma function. Because of its elegant geometry and smooth parametrization, the teardrop curve is often studied alongside related shapes such as pear and piriform curves, making it a beautiful example of how simple equations can generate a wide variety of intricate geometric forms.
