09-15-2026, 03:27 PM
The article by Carlos Sánchez-Linares explains how mathematical modelling turns the physics of tsunamis into practical tools for coastal hazard assessment. Tsunami propagation can be modelled surprisingly effectively with the two-dimensional shallow-water equations, which describe conservation of water mass and momentum while incorporating gravity, ocean depth and the Earth's spherical geometry. The initial disturbance produced by an earthquake is estimated using elastic fault-dislocation models, particularly the Okada formulation.
These equations are then solved numerically using finite-volume methods, high-resolution schemes and wetting/drying algorithms that allow the models to represent steep wave fronts and the movement of the shoreline during inundation. The HySEA modelling framework combines these techniques to simulate both ocean-scale propagation and detailed coastal flooding.
The second major theme is the transition from mathematical equations to operational tsunami-risk systems. The simulations combine high-quality bathymetric and topographic data, realistic or worst-case earthquake scenarios, and nested computational grids: coarse grids model propagation across large ocean regions, while grids down to about 5 metres resolve flooding around individual coastal features and urban infrastructure.
Because these calculations can involve hundreds of millions of computational cells, HySEA exploits GPU-based high-performance computing to make large simulations feasible. The resulting products—such as tsunami arrival times, maximum inundation depth, run-up and flood extent—are incorporated into the Copernicus Emergency Management Service, providing authorities with quantitative information for risk assessment, emergency planning and coastal mitigation.
