Web Analytics
Introduction to Partial Differential Equations [Moore]
Book:Introduction to Partial Differential Equations
Author: John Douglas Moore
Date: May 21, 2003
Publisher/Source: Department of Mathematics, University of California
John Douglas Moore’s Introduction to Partial Differential Equations is a concise introductory text designed to build the mathematical machinery needed to understand the principal linear partial differential equations arising in physics and engineering. Moore emphasizes that PDE theory does not revolve around a single universal theorem; instead, different classes of equations require different techniques. The text therefore develops the subject gradually, beginning with power series, ordinary differential equations, eigenvalues, orthogonality, and Fourier analysis before introducing the main PDE models. Physical motivation is central throughout: vibrating strings and membranes, heat diffusion, mechanical systems, and wave propagation provide the intuition behind the mathematics.
The first three chapters establish the analytical foundations. Power series are used to solve differential equations and introduce Bessel's equation, which later becomes essential for studying circular membranes. The book then develops eigenvalues, symmetric matrices, orthonormal bases, and mechanical systems, emphasizing the connection between linear algebra and differential equations. A substantial chapter on Fourier series introduces sine and cosine expansions, inner products, complex Fourier series, and Fourier transforms. These tools form the basic machinery for expressing solutions of boundary- and initial-value problems as infinite sums of eigenfunctions.
The later chapters concentrate directly on PDEs. Moore studies the heat equation, wave equation, and Laplace equation, including initial-value and boundary-value problems, separation of variables, Sturm–Liouville theory, and numerical approximations. The treatment then extends these ideas to higher dimensions, including the Dirichlet problem, the Laplacian in polar coordinates, eigenvalues of the Laplace operator, and the particularly elegant problem of the vibrating circular membrane, where Bessel functions and Fourier analysis come together. The book ends with an appendix showing how Mathematica can be used to solve differential equations.
Main topics
  • Power series and Bessel functions
  • Eigenvalues, eigenvectors, and orthogonality
  • Fourier series and Fourier transforms
  • Heat equation: $u_t=k\Delta u$
  • Wave equation: $u_{tt}=c^2\Delta u$
  • Laplace equation: $\Delta u=0$
  • Separation of variables
  • Sturm–Liouville theory
  • Initial- and boundary-value problems
  • Numerical approximation of PDEs
  • Eigenvalues of the Laplacian
  • Vibrating strings and circular membranes
  • Mathematica applications
BOOK [PDF]
