Burgers' equation
The Burgers equation is one of the simplest nonlinear partial differential equations that captures the competition between nonlinear transport and diffusion. In one spatial dimension, its viscous form is
$\frac{\partial u}{\partial t}+u\frac{\partial u}{\partial x}=\nu\frac{\partial^2u}{\partial x^2}$
where $u(x,t)$ is the evolving field and $\nu$ is a diffusion or viscosity coefficient. It appears in simplified models of fluid dynamics, nonlinear acoustics, gas dynamics, traffic flow, and mathematical physics. The nonlinear term $u,u_x$ causes regions with larger $u$ to move faster than regions with smaller $u$, which can steepen the profile, while the diffusion term $\nu u_{xx}$ smooths it out.
When $\nu=0$, the equation becomes the inviscid Burgers equation
$u_t+u,u_x=0$
It can initially be solved using the method of characteristics. Along characteristic curves, $u$ remains constant, with
$\frac{dx}{dt}=u,\qquad \frac{du}{dt}=0$
However, characteristics can eventually intersect. At that point, the classical differentiable solution breaks down and a shock wave forms. For initial data $u(x,0)=f(x)$, the first shock can occur at
$t_b=-\frac{1}{\inf_x f'(x)}$
provided the initial profile contains a sufficiently negative slope. This makes Burgers' equation a standard model for understanding how smooth nonlinear PDE solutions can develop very sharp gradients or discontinuities.
The viscous equation has an especially elegant feature: despite being nonlinear, it can be transformed into the linear heat equation using the Cole–Hopf substitution
$u=-2\nu\frac{\partial}{\partial x}\ln\phi$
The resulting function $\phi$ satisfies
$\phi_t=\nu\phi_{xx}$
Thus Burgers' equation provides a rare example in which nonlinear steepening, viscosity, shocks, and exact analytical solutions can all be studied explicitly. It is therefore an important conceptual bridge between elementary PDE theory and much harder nonlinear fluid equations such as the Navier–Stokes equations.
  • Nonlinearity: $u u_x$ produces wave steepening.
  • Viscosity: $\nu u_{xx}$ produces smoothing and dissipation.
  • When $\nu=0$, smooth initial data can develop shocks in finite time.
  • When $\nu>0$, viscosity regularizes the shock into a thin, smooth transition layer.
  • The Cole–Hopf transformation converts the nonlinear Burgers equation into the linear heat equation.
  • Burgers' equation is widely used as a laboratory model for nonlinear PDEs and fluid mechanics, especially for understanding mechanisms that also appear in the Navier–Stokes equations.
ARTICLE / ARTICLE [PDF]
