Web Analytics
Borromean rings
The Borromean rings are a famous object in topology and knot theory, consisting of three closed loops linked together in a striking way: the three-ring system cannot be separated, yet no pair of rings is actually linked by itself. If any one ring is removed, the remaining two immediately fall apart. This makes the Borromean rings the simplest well-known example of a Brunnian link. Their standard diagram has six crossings and is classified as the alternating link $L6a4$. An important geometric subtlety is that three perfectly circular rigid rings in three-dimensional Euclidean space cannot realize the Borromean configuration; ellipses or other deformed loops can.
The rings have surprisingly rich mathematical structure. Their complement in three-dimensional space is a hyperbolic $3$-manifold, decomposable into two ideal regular octahedra, with hyperbolic volume $8G \approx 7.32772$, where $G$ is Catalan's constant. The idea also appears in arithmetic topology: certain triples of primes can behave as arithmetic analogues of Borromean rings, being collectively linked while remaining pairwise unlinked. Similar structures appear in physics through Efimov states and Borromean nuclei, in quantum information through GHZ entanglement, and in chemistry through molecular and DNA Borromean rings.
Historically, the symbol predates its modern mathematical study. It takes its name from the Italian Borromeo family, whose coat of arms featured three interlocking rings, although related motifs appear in several older cultures. Because removing one component destroys the whole linkage, the design has frequently represented unity and mutual dependence. The International Mathematical Union adopted a logo based on the Borromean rings in $2006$.
  • Main mathematical area: Topology $\rightarrow$ Knot theory / Link theory.
  • Three rings are linked collectively, while every pair is unlinked.
  • Removing any ring completely separates the other two: the defining Brunnian property.
  • Perfect circles cannot form true Borromean rings in $\mathbb{R}^3$, although suitably deformed loops can.
  • Their hyperbolic volume is $8G \approx 7.32772$.
  • The structure connects topology with hyperbolic geometry, number theory, chemistry, nuclear physics, and quantum information.
