09-07-2026, 05:11 PM
The freeCodeCamp article “Learn Software Design Basics: Key Phases and Best Practices” explains that effective software development begins well before coding, with a structured design process that makes systems easier to maintain, test, debug, and scale. It outlines five core stages: clearly defining the problem and scope, identifying realistic use cases, specifying detailed requirements, creating a high-level architecture, and developing a detailed component-level design.
Using a Python-based financial expense categorization system as an example, the article demonstrates principles such as modularity, separation of concerns, loose coupling, encapsulation, well-defined interfaces, error handling, telemetry/logging, appropriate data structures, and Test-Driven Development (TDD). It also stresses the importance of explicitly documenting assumptions and design decisions, arguing that thoughtful software design reduces technical debt, prevents costly redesigns, improves collaboration, and produces software that can evolve more easily as requirements grow.
