Fourier Transform — Summary
The Fourier transform is one of the fundamental tools of mathematical analysis. Its central idea is that a function or signal can be represented not only in its original variable—such as time or position—but also in terms of the frequencies from which it is composed. In a standard convention, for an integrable function $f(x)$,
$\widehat{f}(\xi)=\int_{-\infty}^{\infty} f(x)e^{-i2\pi \xi x},dx.$
Here, $\widehat{f}(\xi)$ measures the contribution of frequency $\xi$ to the original function. An inverse Fourier transform can reconstruct $f$ from its frequency representation:
$f(x)=\int_{-\infty}^{\infty}\widehat{f}(\xi)e^{i2\pi \xi x},d\xi.$
A useful analogy is a musical chord: the original sound is a complicated waveform, while its Fourier transform reveals the individual frequencies or pitches that make up the sound and their relative strengths.
The Fourier transform has several powerful mathematical properties. It is linear, converts translations and scalings into simple transformations in the frequency domain, and—most importantly—turns differentiation into multiplication and convolution into ordinary multiplication. This often converts difficult differential or integral problems into much simpler algebraic ones.
Parseval's and Plancherel's theorems show that, under suitable conditions, the transform preserves quantities such as $L^2$ energy:
$\int_{-\infty}^{\infty}|f(x)|^2,dx=\int_{-\infty}^{\infty}|\widehat{f}(\xi)|^2,d\xi.$
There is also an important time–frequency trade-off: a function that is highly localized in time tends to have a Fourier transform spread over many frequencies, while a function concentrated in frequency tends to be spread out in time. This principle is closely connected to the mathematical uncertainty principle.
The Fourier transform has exceptionally broad applications. It was historically motivated by Joseph Fourier's study of the heat equation, but today it is central to solving partial differential equations, signal and image processing, telecommunications, spectroscopy, MRI, probability theory, and quantum mechanics. In quantum mechanics, for example, the position-space and momentum-space descriptions of a particle are related through a Fourier transform.
For digital data, the related Discrete Fourier Transform (DFT) is commonly used. If a sequence contains $N$ values $x_0,x_1,\ldots,x_{N-1}$, its DFT can be written as
$X_k=\sum_{n=0}^{N-1}x_n e^{-i2\pi kn/N},\qquad k=0,1,\ldots,N-1.$
The DFT can be calculated efficiently using the Fast Fourier Transform (FFT) algorithm, making Fourier analysis practical for enormous datasets and real-time signals.
- Main idea: Fourier analysis decomposes complicated functions or signals into combinations of simple oscillations or frequencies.
- Central formula: $\widehat{f}(\xi)=\int_{-\infty}^{\infty}f(x)e^{-i2\pi\xi x},dx$.
- Inverse transform: $f(x)=\int_{-\infty}^{\infty}\widehat{f}(\xi)e^{i2\pi\xi x},d\xi$.
- Major advantage: differentiation and convolution become much simpler operations in frequency space.
- Applications: differential equations, sound, images, communications, spectroscopy, MRI, probability theory, and quantum mechanics.
- Computational version: the DFT and FFT allow Fourier analysis to be applied efficiently to digital data.
