Miquel's theorem
[Image: material-NVnDpFBS.png]
Miquel's theorem
Miquel’s Theorem is a classical result in Euclidean geometry, named after the French mathematician Auguste Miquel, that describes a remarkable property of circles associated with a triangle. Given any triangle and arbitrary points chosen on its sides (or their extensions), three circumcircles can be constructed, each passing through one vertex of the triangle and the two selected points on the adjacent sides. Miquel’s theorem states that these three circles always intersect at a single common point, known as the Miquel point, regardless of where the points are chosen.
The theorem also establishes several elegant angle relationships and has important corollaries, such as the Pivot Theorem when the selected points are collinear. Beyond its original form, it has inspired numerous extensions, including versions for quadrilaterals, pentagons, six-circle configurations, and even three-dimensional geometry.
Miquel’s theorem is a cornerstone of modern triangle geometry because it reveals deep connections between circles, cyclic quadrilaterals, and geometric concurrency, making it a powerful tool in both theoretical research and advanced geometric problem solving.
