Dedekind number
Dedekind number
Named after mathematician Richard Dedekind who introduced them in 1897, Dedekind numbers form a rapidly growing sequence of integers that play a fundamental role in combinatorics and order theory. The nth Dedekind number counts the total number of monotone Boolean functions of n variables, where switching an input from false to true can never cause the output to switch from true to false.
Equivalently, this value measures the count of set antichains on an n-element set, the number of elements in a free distributive lattice generated by n elements, and one more than the number of abstract simplicial complexes on n elements. Despite these clear structural descriptions, determining exact Dedekind numbers presents immense computational challenges because the sequence grows super-exponentially.
Although exact summation formulas and tight asymptotic estimates exist—such as Korshunov's formula—they are either computationally intractable or only approximations. As a result, finding exact values has required extraordinary algorithmic and supercomputing efforts over many decades, progressing slowly from early manual calculations to complex computer searches. The fifth through eighth Dedekind numbers were computed between 1940 and 1991, while the ninth value was solved only recently in 2023 using specialized hardware.
To date, exact Dedekind numbers are known only for values of n up to 9, leaving higher values entirely out of reach for modern computation. Overall, Dedekind numbers serve as a classic benchmark problem illustrating the immense difficulty of counting monotone mathematical structures.
