Conchoid of Nicomedes
The Conchoid of Nicomedes is a classical plane curve studied by the ancient Greek mathematician Nicomedes around 200 BC. It is generated by taking a fixed point (the focus), a fixed line, and marking points at a constant distance from the line along every ray passing through the focus. The curve has polar equation ($r=b+a\sec\theta$) and can also be expressed in Cartesian form as an algebraic curve of degree four. Nicomedes identified three different shapes depending on the ratio between the parameters ($a$) and ($b$), including cases with loops and different branch structures.
 The curve became historically important because it provided solutions to famous Greek geometric problems such as angle trisection and cube duplication, which cannot be solved using only a compass and straightedge. During the 17th century, mathematicians studied the conchoid extensively and used it in various geometric constructions. The curve has an asymptote at ($x=a$), and its properties, including curvature and enclosed areas, can be analyzed using advanced calculus. The name "conchoid" comes from its shell-like appearance, resembling a conch shell.
