07-11-2026, 10:15 PM
Viviani's theorem
Named after the 17th-century Italian mathematician Vincenzo Viviani, Viviani’s theorem is a classic result in geometry stating that for any point located inside an equilateral triangle, the sum of its perpendicular distances to the three sides is always equal to the triangle’s altitude. A simple proof relies on dividing the triangle into three smaller triangles that share the interior point as a common vertex.
Because these smaller triangles have the same base length as the sides of the original equilateral triangle, their combined areas equal the area of the original figure, leading directly to the constant-sum relationship. The theorem is widely taught in mathematics education and frequently appears in geometry problems and mathematical competitions because of its elegant connection between distance and area.
Beyond its original statement, Viviani’s theorem has inspired a variety of extensions and converse results. The same constant-distance property holds for shapes such as parallelograms, regular polygons, equilateral polygons, and even regular polyhedra under appropriate conditions, although the converse is not always valid.
The theorem also has practical applications in ternary plots and flammability diagrams, where distances to the sides of an equilateral triangle provide a natural coordinate system for representing three-component data. These broader generalizations demonstrate how a seemingly simple geometric observation can reveal deep structural properties across mathematics, making Viviani’s theorem an enduring and influential concept in geometry.
