07-06-2026, 10:08 PM
The Euler line is one of the most elegant discoveries in triangle geometry, showing that several important points inside a triangle are connected by a single straight line. For any non-equilateral triangle, the circumcenter (the center of the circle passing through the three vertices), the centroid (the point where the three medians meet and the triangle’s balance point), and the orthocenter (the point where the three altitudes intersect) all lie on the same line, known as the Euler line.
This relationship was discovered by the Swiss mathematician Leonhard Euler in 1765 while studying properties of triangles. The line reveals a deep hidden order in geometry: although these three centers are defined in completely different ways, they are not independent but are connected by a precise mathematical relationship.
In particular, the centroid divides the distance between the circumcenter and orthocenter in a fixed ratio of 2:1, meaning it always lies closer to the circumcenter. The Euler line is a beautiful example of how simple geometric objects can contain surprising structures and how mathematics can uncover connections that are not immediately visible.
