A constructible number is a real number $r$ whose absolute value $|r|$ can be represented as the length of a line segment constructed from a unit segment using only an unmarked straightedge and compass, in finitely many steps. Algebraically, constructible numbers are exactly those that can be obtained from rational numbers using the operations $+$, $-$, $\times$, $\div$, together with repeated extraction of square roots. Thus numbers such as $\sqrt{2}$ are constructible. The constructible numbers form a field containing $\mathbb{Q}$ and contained within the algebraic numbers, creating an important connection between classical Euclidean geometry and abstract algebra.
A real number $\gamma$ is constructible precisely when it belongs to a field obtained from $\mathbb{Q}$ through a finite sequence of quadratic extensions,
$\mathbb{Q}=K_0\subseteq K_1\subseteq\cdots\subseteq K_n,$
where
$[K_i:K_{i-1}]=2.$
Consequently, if $\gamma$ is constructible, then its algebraic degree $[\mathbb{Q}(\gamma):\mathbb{Q}]$ must be a power of $2$. This algebraic interpretation turns geometric construction problems into questions about polynomial degrees, field extensions, and Galois theory.
This theory explains why several famous problems of ancient Greek geometry are impossible using straightedge and compass. Doubling the cube would require constructing $\sqrt[3]{2}$, whose minimal polynomial $x^3-2$ has degree $3$. The general trisection of an angle can similarly lead to irreducible cubic equations. Squaring the circle would require constructing $\sqrt{\pi}$, but $\pi$ is transcendental and therefore not constructible. The theory also characterizes constructible regular polygons through the Gauss–Wantzel theorem.
Key takeaways: Constructibility links Euclidean geometry with field theory and algebra; straightedge-and-compass constructions correspond to successive quadratic extensions; constructible algebraic numbers have degrees restricted by powers of $2$; and the theory provides rigorous proofs of the impossibility of doubling the cube, arbitrary angle trisection, and squaring the circle.
where
$[K_i:K_{i-1}]=2.$
