Going beyond the Golden Ratio [Roberts]
[Martin Roberts]
The article “Going beyond the Golden Ratio” explores why the golden ratio ( $\phi \approx 1.618$ ) is considered the “most irrational” number and investigates other numbers that share similar properties. Using the idea of measuring how well irrational numbers can be approximated by fractions through continued fractions and a scoring system, the author explains that ( $\phi$ ) has the highest possible resistance to rational approximation, with its simple continued fraction ($ [1;\overline{1}]$ ) creating the optimal balance.
The article then shows that this concept extends beyond ( \phi ): numbers such as $(1+\sqrt{2})$ (the silver ratio) and $(9+\sqrt{221})/10)$ are the second and third most irrational numbers, respectively, because they also have special continued fraction patterns and critical approximation limits. The discussion connects number theory, Diophantine approximation, and quadratic irrationals, revealing that the beauty of the golden ratio comes not only from aesthetics but from a deep mathematical property of being exceptionally difficult to approximate with fractions.
