Square pyramid [WIKIPEDIA]
Square pyramid
BY [WIKIPEDIA]
A square pyramid is a three-dimensional geometric solid with a square base and four triangular faces that meet at a single point called the apex. It has 5 faces in total, 8 edges, and 5 vertices. The height is the perpendicular distance from the apex to the center of the square base, and the slant height is the height of each triangular face.
 Its surface area is the sum of the base area and the areas of the four triangular faces, while its volume is given by $ (V = \frac{1}{3} \times \text{base area} \times \text{height})$. Square pyramids appear in geometry, architecture, and engineering due to their stable and symmetrical structure.
ARTICLE PAGE
