The mathematics of diseases
The Mathematics of Diseases — Matt Keeling
Plus Magazine, 1 March 2001
The article explains how mathematical modelling can describe and predict the spread of infectious diseases, focusing on the classic SIR model. A population is divided into three groups: susceptible $S$, infectious $I$, and recovered $R$. Individuals move from susceptibility to infection through contact with infectious people and eventually recover, often gaining immunity. These transitions can be represented by differential equations such as
$\displaystyle \frac{dS}{dt}=B-\beta SI-dS$
$\displaystyle \frac{dI}{dt}=\beta SI-gI-dI$
$\displaystyle \frac{dR}{dt}=gI-dR$
where $\beta$ describes transmission, $1/g$ is the average infectious period, and $B$ and $d$ represent births and deaths. Despite its simplicity, the SIR framework can reproduce important epidemic behaviour, including rapid outbreaks followed by decline and, when births continually introduce new susceptible individuals, long-term endemic patterns.
A central quantity is the basic reproduction number $R_0$, defined as the average number of secondary infections produced by one infected individual in a fully susceptible population. In the simple model,
$\displaystyle R_0=\frac{\beta}{g}$
If $R_0>1$, an epidemic can grow; if $R_0<1$, transmission eventually dies out. The same parameter determines important quantities such as the equilibrium susceptible fraction,
$\displaystyle S^*=\frac{1}{R_0}$
and the approximate vaccination threshold needed to prevent sustained transmission,
$\displaystyle V_T=1-\frac{1}{R_0}$
Thus, highly transmissible diseases require much higher levels of population immunity. The article also shows how the final size of an outbreak can be estimated through an implicit equation such as
$\displaystyle S_\infty=\exp!\left[(S_\infty-1)R_0\right]$
This illustrates how even relatively modest increases in $R_0$ can greatly increase the proportion of a population eventually infected.
Keeling stresses that realistic epidemiology goes far beyond the elementary SIR equations. Models may incorporate age structure, school-term seasonality, different patterns of social contact, animal or insect vectors, spatial movement, and demographic change. The 2001 UK foot-and-mouth outbreak is presented as an example in which mathematical modelling could guide control strategies such as restricting livestock movement and removing infected animals.
The larger lesson is that epidemiology combines differential equations, dynamical systems, statistics, and real-world data. Mathematical models simplify reality, but they can reveal thresholds, mechanisms, and intervention strategies that are difficult to infer from raw case counts alone.
  • The SIR model represents epidemic dynamics through the interacting populations $S$, $I$, and $R$.
  • $R_0$ acts as a fundamental threshold: $R_0>1$ permits epidemic growth, while $R_0<1$ prevents sustained spread.
  • Herd immunity follows mathematically from reducing the susceptible population below the critical level $1/R_0$.
  • Real epidemiological modelling extends simple SIR equations with demographic, behavioural, seasonal, and spatial information.
ARTICLE / PDF
