Monsky's theorem
Monsky's theorem
Monsky's theorem is a surprising result in geometry that says a square can never be divided into an odd number of triangles that all have exactly the same area. At first this sounds like a simple puzzle about cutting shapes, but the proof reveals deep connections between geometry, algebra, and combinatorics. The problem was posed in the 1960s and was finally solved by Paul Monsky in 1970.
His idea was to color the points of the square using a special rule based on the powers of 2 hidden in their coordinates. This coloring creates a restriction: certain triangles must have vertices with three different colors, and such triangles cannot have the same area as would be required in an odd equal-area division.
The argument uses tools such as Sperner's lemma and 2-adic methods, showing that even a simple-looking question about cutting a square hides unexpected arithmetic structure. The theorem has since been generalized to other shapes and higher-dimensional cubes, becoming a beautiful example of how elementary geometry can lead to sophisticated mathematics.
