07-04-2026, 03:13 PM
A geometric proof of the impossibility of angle trisection
BY TERENCE TAO
While modern mathematics traditionally relies on complex field theory to prove that you can't trisect an arbitrary angle with just a straightedge and compass, mathematician Terence Tao explores a much more visual, intuitive alternative using a concept called monodromy.
To understand the difference between what's possible and what isn't, think about bisecting an angle: if you dynamically rotate your starting points in a full circle, the lines you construct move smoothly alongside them, eventually returning to where they started or shifting to a predictable symmetry because 2 divides evenly into powers of 2.
However, trying to stretch this fluid, rotational logic to a trisection breaks down because no power of 2 is evenly divisible by 3. Tao demonstrates that if you try to continuous-loop an angle trisection construction through multiple rotations, the lines wind up trapped in an impossible geometric knot, transforming into completely different lines rather than returning to their origin.
By shifting the problem away from abstract algebraic fields and into the physical sensation of rotating and tracking shapes across continuous loops, Tao gives us a beautifully geometric way to see exactly why ancient mathematicians were chasing a mathematical mirage.
