LangGraph Essentials
LangGraph Essentials – Python
Source: LangChain Academy
Course:Quickstart: LangGraph Essentials – Python
This short course is a practical introduction to LangGraph, LangChain’s low-level framework for building stateful and controllable AI-agent workflows in Python. Rather than treating an agent as a simple linear chain of prompts, LangGraph models an application as a graph whose components maintain and modify shared state. The course introduces the central primitives: nodes, where computation or LLM/tool operations occur; edges, which determine how execution moves between nodes; and conditional edges, which allow the workflow to choose different paths depending on the current state or an agent’s decision.
The course then moves to two especially important capabilities for agentic systems: memory and human-in-the-loop control. LangGraph can persist graph state through checkpoints, allowing an agent to retain conversational or workflow context and resume execution later. The mechanism allows execution to pause so a person can review, approve, modify, or provide additional information before the workflow continues. These features make LangGraph particularly useful for applications that are more complex than ordinary chatbot loops—for example, research agents, approval workflows, multi-stage automation, and agents performing potentially consequential actions.
The final lesson brings these elements together into an application, showing the underlying architecture of a LangGraph program: define the application state, implement nodes that transform that state, connect them with normal or conditional edges, add persistence where needed, and compile the resulting graph into an executable workflow. LangGraph is therefore best understood not simply as another LLM library, but as an orchestration/runtime layer for sophisticated agents, particularly when developers need precise control over execution, persistent state, branching logic, interruptions, and durable workflows. LangChain itself recommends LangGraph for advanced cases combining deterministic application logic with agentic behavior.
Course structure
  1. Nodes — individual units of computation.
  2. Edges — transitions between nodes.
  3. Conditional Edges — dynamic branching of execution.
  4. Memory — persistence of state and conversation context.
  5. Interrupt / Human-in-the-Loop — pausing and resuming workflows with human intervention.
  6. Application — combining the concepts into a working LangGraph program.
COURSE
