09-05-2026, 11:53 PM
Manifolds, Differential Forms, and Multivariable Calculus
Published: September 5, 2026
The article gives an intuitive introduction to differential geometry by asking how ordinary calculus can be extended from flat Euclidean space to curved objects such as spheres and manifolds. It begins with the derivative and gradient, then introduces the tangent space $T_pM$, which describes all infinitesimal directions in which one can move while remaining on a manifold $M$. Instead of thinking of derivatives only as vectors, the article emphasizes the more natural notion of a covector: a linear map that takes tangent vectors to numbers. Thus the derivative of $f:M\to\mathbb R$ becomes the covector $df$, satisfying approximately
$ f(p+v)-f(p)\approx df_p(v). $
This perspective also explains why expressions such as $dx$, $dy$, and $dz$ can be treated as meaningful mathematical objects rather than merely formal notation.
The discussion then moves from ordinary integration to line integrals. A differential $1$-form $\omega$ assigns a covector to every point of a manifold, allowing integration along a curve $\gamma$ through
$ \displaystyle \int_\gamma\omega=\int_0^1\omega_{\gamma(t)}(\gamma'(t)),dt. $
For exact forms $df$, the fundamental theorem of calculus becomes the geometric statement
$ \displaystyle f(q)-f(p)=\int_\gamma df. $
The same idea is extended to surfaces using differential $2$-forms, which take two tangent vectors as inputs and measure oriented quantities such as flux through an infinitesimal parallelogram. More generally, a differential $k$-form acts on $k$ tangent vectors and can be integrated over a $k$-dimensional region.
The culmination is Stokes' theorem, which unifies many familiar results of calculus into the single formula
$ \displaystyle \int_{\sigma} d\omega=\int_{\partial\sigma}\omega. $
It says that integrating the derivative of a differential form over a region is equivalent to integrating the original form over the region's boundary. The ordinary fundamental theorem of calculus, Green's theorem, the classical Stokes theorem, and divergence-type results can all be viewed as manifestations of this principle. The article therefore presents differential forms as the natural language for doing calculus on arbitrary curved spaces and as one of the foundational tools of differential geometry and mathematical physics.
- A tangent space $T_pM$ describes the allowable infinitesimal directions at a point of a manifold.
- A $1$-form converts tangent vectors into numbers and is naturally integrated along curves.
- A $k$-form acts on $k$ tangent vectors and can be integrated over $k$-dimensional regions.
- The exterior derivative $d$ turns a $k$-form into a $(k+1)$-form.
- Stokes' theorem, $\displaystyle \int_M d\omega=\int_{\partial M}\omega$, is the central unifying principle behind much of multivariable calculus.
