Kakeya set
A Kakeya set, also called a Besicovitch set, is a subset of Euclidean space that contains a unit line segment in every possible direction. The subject began with Sōichi Kakeya’s 1917 needle problem, which asked for the smallest planar region in which a needle of length $1$ can be rotated through a full $360^\circ$. For convex regions, Gyula Pál proved that the minimum is attained by an equilateral triangle of height $1$, whose area is $1/\sqrt{3}$. The surprising development came from Abram Besicovitch, who showed that a set containing a unit segment in every direction can have Lebesgue measure zero. He later showed that a needle can be continuously rotated inside regions of arbitrarily small positive area. Constructions such as the Perron tree achieve this by cutting triangles into many thin pieces and arranging them so that they overlap heavily while still representing all required directions.
The modern problem asks not about area but about dimension. The Kakeya conjecture states that if $K\subset\mathbb{R}^n$ contains a unit line segment in every direction, then
$\dim_H(K)=n$,
where $\dim_H$ denotes Hausdorff dimension. Thus, although a Kakeya set can have zero ordinary volume, it should still have the full geometric dimension of the space containing it. The conjecture is known for $n=1,2,3$, while dimensions $n>3$ remain open. In February 2025, Hong Wang and Joshua Zahl posted a proof of the three-dimensional case, work for which Wang was later awarded a 2026 Fields Medal in part. Kakeya problems are fundamental in geometric measure theory and have deep connections with harmonic analysis, Fourier analysis, the restriction conjecture, Bochner–Riesz problems, local smoothing, and additive combinatorics. The finite-field version was solved by Zeev Dvir in 2008 using the polynomial method.
  • A Kakeya set contains a unit line segment in every direction.
  • Besicovitch showed that such a set can have measure zero.
  • A needle can nevertheless be rotated through $360^\circ$ inside regions of arbitrarily small positive area.
  • The Kakeya conjecture predicts that every Kakeya set in $\mathbb{R}^n$ has full Hausdorff dimension $n$.
  • The conjecture is established for $n\leq3$ but remains open for $n>3$.
