Carl Friedrich Gauss : Unusual Facts [mklab.gr]
CARL FRIEDRICH GAUSS (1777–1855)
53 Unusual and Lesser-Known Facts About the “Prince of Mathematicians”
Carl Friedrich Gauss is remembered as one of the greatest mathematicians in history. His contributions transformed number theory, geometry, astronomy, statistics, geodesy and physics.
Yet behind the familiar image of the Princeps Mathematicorum — the “Prince of Mathematicians” — was a remarkably complex man: intensely private, extraordinarily calculating, reluctant to publish, fascinated by numerical curiosities, financially shrewd and responsible for discoveries that sometimes remained hidden for decades.
The following collection brings together 53 unusual and lesser-known facts about his life and work.
I. CHILDHOOD, LEGENDS AND THE 17-GON
1. The famous 1 + 2 + ... + 100 story is probably embellished
The celebrated story says that the young Gauss was ordered to add the integers from 1 to 100 and almost immediately produced
5050.
There really is an early account of Gauss astonishing his schoolteacher with an arithmetic-series calculation. However, the earliest source does not say that the numbers were specifically 1 through 100, nor does it describe the familiar trick of pairing
1 + 100, 2 + 99, 3 + 98, ...
The explicit modern version seems to have appeared much later.
2. The three-year-old who corrected a payroll calculation
A considerably better-attested childhood story says that when Gauss was about three years old, his father was calculating the wages of some workers.
The young Gauss supposedly announced that the total was wrong — and supplied the correct answer.
3. He claimed he could calculate before he could speak
Gauss later joked that he had learned to reckon before he had properly learned to talk.
4. One discovery may have determined his entire career
As a teenager, Gauss was seriously interested not only in mathematics but also in philology.
In March 1796 he discovered that a regular polygon with 17 sides could be constructed using only a straightedge and compass.
The discovery apparently convinced him to devote his life to mathematics.
5. He supposedly wanted a 17-gon on his tombstone
The construction of the regular 17-gon was the first major advance in the classical problem of constructing regular polygons for more than two thousand years.
According to tradition, Gauss was so proud of the result that he wanted a 17-gon carved on his tombstone.
The stonemason supposedly refused, arguing that a 17-sided polygon would look almost indistinguishable from a circle.
II. THE SECRET MATHEMATICAL DIARY
6. Gauss kept an extraordinary private mathematical diary
Between 1796 and 1814 Gauss maintained a private mathematical diary.
The surviving notebook is only about 19 pages long, yet it contains 146 extremely compressed entries recording discoveries, several of which anticipated later mathematics by years or even decades.
7. The original diary still survives
Gauss's mathematical diary is preserved in Göttingen as
Cod. Ms. Gauß Math. 48 Cim.
It has been digitized and can still be examined today.
Much of it is written in Latin.
8. Some entries remain extremely cryptic
Gauss often recorded little more than a few words, symbols or hints.
Historians have sometimes struggled to determine exactly what he meant, and some diary entries remain difficult to connect with his later mathematics.
9. Gauss actually wrote “EUREKA!” after a discovery
On 10 July 1796, the nineteen-year-old Gauss wrote the Greek word
ΕΥΡΗΚΑ!
followed by the mysterious formula
num = Δ + Δ + Δ
The entry commemorated his proof that every positive integer can be represented as the sum of at most three triangular numbers.
10. The mysterious “Vicimus GEGAN”
Another famous diary entry reads:
Quote:Vicimus GEGAN
roughly, “We have conquered GEGAN.”
The cryptic phrase was later interpreted as referring to Gauss's discovery of a profound relationship between the arithmetic-geometric mean and elliptic functions.
III. THE MATHEMATICS GAUSS DID NOT PUBLISH
11. His motto was “Pauca sed matura”
Gauss adopted the Latin motto
Quote:Pauca sed matura — “Few, but ripe.”
He preferred to publish only results that he considered completely mature, polished and elegant.
12. His perfectionism cost him priority
Gauss repeatedly discovered important mathematics and then failed to publish it.
Consequently, other mathematicians sometimes independently rediscovered ideas that Gauss had already developed privately.
13. He anticipated the Fast Fourier Transform by about 160 years
Around 1805, while working on astronomical calculations involving the asteroids Pallas and Juno, Gauss used a factorisation technique essentially equivalent to a central idea of the modern Fast Fourier Transform.
The famous Cooley-Tukey FFT appeared in 1965.
Gauss's work had remained unpublished as a general computational algorithm.
14. He explored non-Euclidean geometry before Bolyai and Lobachevsky
Gauss had developed substantial ideas about geometries in which Euclid's parallel postulate does not hold long before János Bolyai and Nikolai Lobachevsky published their work.
When Bolyai's work was sent to Gauss, he famously replied that praising it would essentially amount to
Quote:“praising myself”
because he had contemplated similar ideas for decades.
15. He deliberately kept his non-Euclidean work private
Gauss apparently feared the philosophical controversy that openly challenging Euclidean geometry might provoke.
Instead of publishing his ideas, he kept most of them private.
16. In his sixties he learned Russian
Gauss taught himself Russian comparatively late in life.
One reason appears to have been his desire to read Russian scientific literature, including Lobachevsky's work on non-Euclidean geometry.
He later supported Lobachevsky's election to the Göttingen scientific society.
IV. “GAUSSIAN” THINGS THAT GAUSS DID NOT ACTUALLY INVENT
17. Gauss did not discover the Gaussian distribution
The normal distribution is commonly called the Gaussian distribution, but Abraham de Moivre had obtained the normal curve decades earlier.
Gauss's name became strongly associated with it because of his enormously influential work on observational errors and astronomical measurement.
18. He did not invent Gaussian elimination either
Algorithms essentially equivalent to Gaussian elimination appear in ancient Chinese mathematics.
Gauss played an important role in its later computational development and application, but he was not its original inventor.
19. He fought a priority dispute over least squares
Adrien-Marie Legendre published the method of least squares in 1805.
When Gauss published his own treatment in 1809, he claimed to have been using the principle since 1795.
Legendre was understandably furious.
Historical evidence suggests that Gauss probably did know the method earlier, but Legendre unquestionably published first.
20. One of his early publications concerned Easter
Gauss's first publication after his doctoral dissertation was not about number theory.
In 1800 he published an algorithm for calculating the date of Easter using modular arithmetic.
Even Gauss's formula was not flawless: a later correction was required.
21. Did he calculate his own birthday? Perhaps
According to a famous tradition, Gauss's mother could not remember his exact birth date.
She supposedly remembered only that he had been born on a Wednesday, eight days before Ascension Day.
From this information the date can be reconstructed as
30 April 1777.
The story is charming, but historians have warned that the connection between Gauss's Easter calculations and the discovery of his own birthday may be legendary.
V. BOOKS, CHILDREN AND ASTRONOMY
22. His first Göttingen library loan was a romantic novel
The first book Gauss is recorded as borrowing after arriving at Göttingen University in 1795 was not mathematics.
It was Samuel Richardson's enormous eighteenth-century novel
Clarissa.
23. He named children after asteroid discoverers
Several of Gauss's children were given names connected with astronomers associated with newly discovered minor planets.
Joseph was named for Giuseppe Piazzi, Wilhelmine for Wilhelm Olbers, and Louis/Ludwig for Karl Ludwig Harding.
24. He mathematically recovered the lost Ceres
In 1801 Giuseppe Piazzi discovered Ceres but lost sight of it after it passed behind the Sun.
From a limited collection of observations, Gauss calculated its orbit and predicted where astronomers should search.
Ceres was subsequently recovered close to the predicted position.
25. Ceres made Gauss internationally famous
The spectacular recovery of Ceres demonstrated that pure mathematical calculation could solve a dramatic practical astronomical problem.
It greatly enhanced Gauss's reputation as a computational astronomer.
26. He invented the heliotrope
While participating in the geodetic survey of Hanover, Gauss invented the heliotrope.
The instrument used mirrors to reflect sunlight toward distant survey stations, improving the visibility and precision of long-distance measurements.
27. Gauss personally did difficult fieldwork
He did not simply perform calculations from the comfort of an observatory.
During the Hanover survey Gauss personally spent long periods making field observations and then reduced the measurements mathematically at night.
VI. GAUSS THE INVENTOR
28. Gauss and Weber built an electromagnetic telegraph
In 1833 Gauss and physicist Wilhelm Weber constructed an early working electromagnetic telegraph in Göttingen.
It connected Gauss's observatory with Weber's workplace and was used to transmit coded signals and coordinate magnetic experiments.
29. Their telegraph existed before Morse's famous system
The Gauss-Weber telegraph preceded Samuel Morse's better-known system.
The research sources differ over the exact quoted length of the wire, giving figures between approximately 1.5 and 3 kilometres, but agree that it was a functioning electromagnetic telegraph connection across Göttingen.
VII. GAUSS AS A TEACHER
30. He was not enthusiastic about teaching
Gauss often regarded routine university teaching as an intrusion into the time he could devote to research.
Richard Dedekind recalled that Gauss himself warned that it was always uncertain whether one of his announced courses would actually take place.
31. His barber apparently served as messenger
When enough students finally enrolled in Gauss's course on least squares, Gauss reportedly informed Dedekind through a man they both knew:
their barber.
Only nine students attended.
32. Yet Dedekind considered the lectures magnificent
Despite Gauss's reluctance to teach, Dedekind later described the course as one of the finest series of lectures he had ever attended.
According to Dedekind, Gauss's enthusiasm increased once the course began.
33. He reportedly discouraged note-taking
One source reports that Gauss did not want students constantly writing during his lectures.
He preferred them to listen and concentrate on the mathematical argument.
VIII. NEWSPAPERS, BOOKS AND PERSONAL QUIRKS
34. He was nicknamed the “Newspaper Tiger”
Gauss was an enthusiastic newspaper reader.
According to one account, he gained the nickname
“Newspaper Tiger”
because he would quickly seize unattended newspapers to read them.
Dedekind later remembered regularly seeing the elderly Gauss reading newspapers at Göttingen's Literary Museum.
35. His library contained 1,715 titles
Gauss was a voracious reader whose interests extended well beyond mathematics.
The preserved Gauss Library in Göttingen contains 1,715 titles, including mathematics, astronomy, classical literature, belles-lettres and travel writing.
36. The velvet cap became part of his image
Gauss was frequently seen wearing a small velvet cap.
He also smoked a pipe, enjoyed wine, had notably neat handwriting and kept a notebook containing lists of favorite songs.
37. He collected numerical trivia
Gauss's fascination with numbers did not stop when he left mathematics.
One source says that in later life he recorded numerical curiosities such as possible walking routes, people's ages expressed in days and unusual coincidences involving lifespans.
IX. THE MATHEMATICIAN WHO BECAME RICH
38. Gauss managed a widows' pension fund
Göttingen University entrusted Gauss with its widows' pension fund.
The responsibility drew him into actuarial mathematics, financial calculations and recommendations concerning the stability of the fund.
39. He died remarkably wealthy
Despite the modest public image of an academic and observatory director, Gauss accumulated considerable wealth.
He lived frugally and invested successfully in securities and bonds.
One source estimates his estate at more than
170,000 thalers
— vastly greater than his annual academic salary.
40. He had a reputation for extreme thrift
His financial habits contributed to a reputation for miserliness.
But those same habits, combined with skilled investing, transformed his comparatively ordinary academic income into a substantial fortune.
X. FAMILY LIFE
41. His private life included considerable tragedy
Gauss married twice and was widowed twice.
The sources describe him as deeply attached to his first wife, Johanna, while his later family relationships were more complicated.
42. Two sons emigrated to the United States
Gauss had serious conflicts with some of his sons.
Two eventually left Germany for the United States.
One source reports that Eugene learned fluent Sioux and became a successful banker, while Wilhelm became a prosperous shoe manufacturer in St. Louis.
43. He once supposedly called Eugene a “good-for-nothing”
One source records Gauss referring to Eugene using the German word
Taugenichts
— approximately “good-for-nothing” — illustrating how severe their relationship could become.
44. He was deeply devoted to his mother
Gauss's mother was barely literate, yet she lived to the remarkable age of 97.
She spent the final 22 years of her life in Gauss's home, and he remained deeply attached to her.
XI. ACADEMIC CURIOSITIES AND LEGACY
45. He obtained his doctorate without the normal oral examination
Gauss received his doctorate from the University of Helmstedt in 1799.
He obtained it in absentia, and the normal oral examination was waived.
His dissertation concerned the fundamental theorem of algebra.
46. Gauss chose the lecture that led to Riemannian geometry
In 1854 Bernhard Riemann had to submit three possible subjects for his habilitation lecture.
Gauss selected the topic concerning
“the hypotheses which lie at the foundations of geometry.”
The resulting lecture became one of the foundational documents of what is now called Riemannian geometry.
47. Gauss may also have been a caricaturist
One source reports that as a student Gauss drew a caricature of professor Abraham Gotthelf Kästner after the professor made an arithmetic error on the blackboard.
It offers an unusual glimpse of Gauss's humor and artistic side.
48. The magnetic unit “gauss” bears his name
The CGS unit of magnetic flux density, the gauss (G), was named in his honor.
This is particularly appropriate given Gauss's major investigations of terrestrial magnetism and his collaboration with Wilhelm Weber.
49. His portrait appeared on German money
Long after his death, Gauss became a familiar face in everyday German life.
His portrait appeared on the German 10-mark banknote as well as on commemorative coins.
XII. THE STRANGE STORY OF GAUSS'S BRAIN
50. His preserved brain spent decades in the wrong jar
After Gauss died in 1855, his brain was removed and preserved for scientific study.
In 2013 researchers discovered something extraordinary.
The preserved brains of Gauss and Göttingen physician Conrad Heinrich Fuchs had apparently been switched, probably during the nineteenth century.
The jar labelled as containing Gauss's brain apparently contained Fuchs's, and vice versa.
51. His real brain appeared surprisingly ordinary
Once the correct specimen was identified, modern investigators found no spectacular anatomical feature that could explain Gauss's genius.
His brain was described as broadly normal for a man who had died at the age of 78.
XIII. STORIES THAT SHOULD BE TREATED WITH CAUTION
52. “Tell her to wait until I'm finished” is probably not reliable
A famous anecdote claims that while Gauss was deeply absorbed in a mathematical problem, someone informed him that his wife was dying.
He supposedly responded:
Quote:“Tell her to wait until I'm finished.”
It is a memorable story, but the historical evidence is weak, and it should be treated as possibly apocryphal rather than as established fact.
53. The legends surrounding Gauss reveal something important
Several of the most famous stories about Gauss appear to contain a genuine historical core but acquired sharper and more dramatic details through repeated retelling.
The two clearest examples are:
the schoolboy story of summing the integers from 1 to 100;
the story that Gauss devised his Easter algorithm specifically to determine his own birthday.
They are excellent stories — but they should not be confused with completely secure historical facts.
CONCLUSION
Gauss's achievements alone would have been enough to secure his place among the greatest mathematicians who ever lived. What makes his biography even more remarkable, however, is how much of his work remained hidden.
He anticipated mathematical developments that would only become famous decades or even more than a century later. He helped recover a lost celestial body, invented a surveying instrument, constructed an early electromagnetic telegraph, investigated non-Euclidean geometry in private, managed pension finances and quietly accumulated a considerable fortune.
Perhaps the most revealing phrase remains his own motto:
Pauca sed matura
“Few, but ripe.”
It explains both Gauss's extraordinary standards and one of the great ironies of his career: one of history's most productive mathematical minds published far less than he actually discovered.
