On writing papers [Terry Tao]
Summary: Terry Tao’s “Advice on Writing Papers”
Terry Tao explains that good mathematical writing does not follow a fixed formula; instead, authors should develop a style that matches their strengths, the subject, and the intended audience. A successful paper should begin by clearly presenting and motivating its main ideas, using the introduction to highlight the importance of the results while remaining accurate and honest.
The organization of the paper is essential: authors should choose good notation, divide complex arguments into manageable sections or lemmas, and provide enough detail so readers can understand the key ideas without being overwhelmed by routine calculations. Tao recommends creating a quick prototype draft before polishing the final version, writing in a professional but personal voice, and using natural language rather than relying only on mathematical symbols.
Authors should focus their effort on the most important and innovative parts of the work, while avoiding unnecessary optimization that may make the paper longer or less clear. Before submission, a paper should be carefully proofread and sent to an appropriate journal. Ultimately, Tao emphasizes that mathematical writing is about communication: the goal is not only to present correct results but also to help readers understand why those results matter and how the ideas fit together.
Key takeaways:
  • A paper should communicate ideas, not just contain proofs.
  • The introduction should explain the significance of the results.
  • Good structure and notation greatly improve readability.
  • Give more space to important ideas and less to routine details.
  • Write a draft quickly, then refine it.
  • Avoid perfectionism that harms clarity or efficiency.
  • Submit only a polished, carefully checked final version.
