Shoelace formula - Printable Version
+----- Thread: Shoelace formula (/showthread.php?tid=950)
Shoelace formula - mklabgr - 07-07-2026
Shoelace formula
The shoelace formula is a simple yet powerful method in computational geometry and mathematics for calculating the area of a polygon when the coordinates of its vertices are known. Named because the cross-multiplication pattern resembles the lacing of a shoe, the formula uses the ordered coordinates of the polygon’s corners to determine its signed area through a series of additions and subtractions.
By multiplying each x-coordinate by the next y-coordinate and subtracting the reverse products, the method efficiently finds the area of both simple polygons and irregular shapes without needing to divide them into triangles manually.
The shoelace formula is closely connected to concepts from analytic geometry, determinants, and the geometric interpretation of cross products. Beyond calculating areas, its signed version can reveal the orientation of a polygon’s vertices, distinguishing between clockwise and counterclockwise ordering.
Because of its simplicity and computational efficiency, it is widely used in computer graphics, geographic information systems (GIS), surveying, and algorithm design. The formula demonstrates how a compact mathematical idea can transform coordinate data into meaningful geometric information, making it an important tool in modern applications where accurate and efficient spatial calculations are essential.
BOOK
