Maclaurin's inequality - Printable Version
+----- Thread: Maclaurin's inequality (/showthread.php?tid=802)
Maclaurin's inequality - mklabgr - 06-27-2026
Maclaurin's inequality is a fundamental result in mathematics that describes a relationship between different types of averages of positive numbers, showing that as we move from simpler averages to more complex ones, their values follow a specific decreasing pattern. It connects elementary symmetric sums with the idea of means and helps explain why certain inequalities hold in algebra, geometry, and optimization.
Named after the Scottish mathematician Colin Maclaurin, the inequality is a powerful tool for comparing quantities and proving many other mathematical results. Although the formula may look abstract at first, the main idea is intuitive: combining numbers in different ways produces averages that are not equal, and Maclaurin's inequality reveals the hidden order behind these relationships.
