Cadabra - Printable Version +- MKLab (https://mklab.gr) +-- Forum: [INDEX] (https://mklab.gr/forumdisplay.php?fid=1) +--- Forum: LISTS (https://mklab.gr/forumdisplay.php?fid=43) +---- Forum: SCIENTIFIC SOFTWARE (https://mklab.gr/forumdisplay.php?fid=44) +----- Forum: COMPUTER ALGEBRA SYSTEMS (CAS) (https://mklab.gr/forumdisplay.php?fid=75) +----- Thread: Cadabra (/showthread.php?tid=574) |
Cadabra - mklabgr - 06-22-2026 Cadabra is a symbolic computer algebra system (CAS) designed especially for theoretical and mathematical physics, with a strong focus on field theory and tensor calculations. It can manipulate tensors with complicated symmetries, fermionic and non-commuting quantities, Clifford algebras, gamma matrices, Fierz identities, covariant derivatives, and both abstract and component expressions. Mathematical input and output use a subset of LaTeX, while computations can be programmed in Python; the underlying system is largely implemented in C++. Cadabra can be used from a command line, its own notebook interface, or through Jupyter, and it can also interact with SymPy. A distinctive feature of Cadabra is its philosophy of keeping the mathematician in control. Instead of automatically simplifying every expression into what the software considers a canonical form, Cadabra generally leaves expressions unchanged until the user explicitly requests a transformation. This makes it behave more like a mathematical scratchpad, which is particularly useful in research calculations where several valid manipulation paths may exist. The project began around 2001 for work on higher-derivative supergravity, was first publicly released in 2007, and underwent a major rewrite into Cadabra 2 during 2015–2016. Recent releases have improved plotting, the notebook interface, SymPy integration, component calculations, performance, and usability. Cadabra |
