Illumination problem - Printable Version
+----- Thread: Illumination problem (/showthread.php?tid=546)
Illumination problem - mklabgr - 06-21-2026
The Illumination Problem is a famous problem in geometry, originally posed by Ernst Straus in the 1950s, asking whether a room with perfectly mirrored walls can always be completely illuminated by a single point light source, even after allowing infinitely many reflections.
The problem is closely related to billiard-ball trajectories in rooms of arbitrary shape. In 1958, Roger Penrose showed that the answer is no by constructing a curved-walled “unilluminable room” containing permanently dark regions. Later, researchers such as George Tokarsky discovered polygonal rooms with special points that cannot be illuminated from certain locations, despite repeated reflections.
More recent work has shown that for many polygonal rooms with rational angles, all but finitely many points can be illuminated. The illumination problem has deep connections to geometry, dynamical systems, and the mathematics of billiards, and it remains an active area of research in several related forms.
