A First Introduction to Statistical Significance - Printable Version
+----- Thread: A First Introduction to Statistical Significance (/showthread.php?tid=531)
A First Introduction to Statistical Significance - mklabgr - 06-21-2026
BY  Scott Hartshorn
The article “A First Introduction to Statistical Significance” from Math Vault explains the idea of statistical significance through simple examples such as dice rolls and measurements. Statistical significance is a way to determine whether an observed difference is likely to be a real effect or just a result of random variation.
The article introduces the Z-test, which compares the size of a difference from an expected value with the amount of natural variation in the data; a larger Z-value means the observation is more unusual. It explains the role of standard deviation, sample size, and the fact that larger samples reduce uncertainty in averages.
Using examples like tire lifetimes, it shows that an unusual result may suggest a real cause rather than coincidence, but statistical tests help measure how unlikely that result is under normal conditions. The same principles apply to other methods such as the T-test, which also rely on understanding variation and sample averages.
[url=https://mathvault.ca/statistical-significance/?utm_source=chatgpt.com][/url]
