How do you find the positive integer solutions - Printable Version
+----- Forum: NUMBER THEORY (https://mklab.gr/forumdisplay.php?fid=148)
+----- Thread: How do you find the positive integer solutions (/showthread.php?tid=526)
How do you find the positive integer solutions - mklabgr - 06-21-2026
BY ALON AMIT
The problem asks for positive integer solutions to the Diophantine equation
$\frac{x}{y+z}+\frac{y}{x+z}+\frac{z}{x+y}=4$
and turns out to be a surprisingly difficult number theory problem. Simple searches for small values find nothing, but positive solutions do exist and are extraordinarily large. By clearing denominators, the equation becomes a cubic surface, which can be transformed into an elliptic curve problem; methods from elliptic curve theory are then used to generate integer points.
The smallest known positive solution has hundreds of digits, with (x), (y), and (z) being enormous numbers, showing that some mathematical problems can look simple but hide deep structures requiring advanced techniques rather than brute force.
