Magic Angle [Wikipedia] - Printable Version
+----- Thread: Magic Angle [Wikipedia] (/showthread.php?tid=330)
Magic Angle [Wikipedia] - mklabgr - 06-14-2026
The magic angle, approximately equal to 54.74° ($\theta_{\mathrm{m}} = \arccos(1/\sqrt{3})$), is a precisely defined angle derived as the root of a second-order Legendre polynomial ($P_2(\cos \theta) = 0$), meaning that any physical interaction dependent on this mathematical function completely vanishes at this orientation. Structurally, it represents the angle between the space diagonal of a cube and any of its three connecting edges, and doubling this value gives the 109.47° tetrahedral angle central to molecular geometry. Because it cancels out anisotropic angular dependencies, the magic angle is critically utilized in magic-angle spinning (MAS) solid-state NMR spectroscopy to remove line-broadening interactions and dramatically improve spectral resolution. Furthermore, it appears in medical imaging as the "magic angle artifact," where highly ordered collagen tissues like tendons appear artificially bright on an MRI when oriented at this angle to the magnetic field, and it is even utilized in engineering to construct reinforced rubber hoses where a 54.7° fiber alignment perfectly balances longitudinal and circumferential internal pressures.
ARTICLE PAGE
