Network theory - Printable Version +- MKLab (https://mklab.gr) +-- Forum: [INDEX] (https://mklab.gr/forumdisplay.php?fid=1) +--- Forum: MATHEMATICS (https://mklab.gr/forumdisplay.php?fid=3) +---- Forum: ARTICLES (https://mklab.gr/forumdisplay.php?fid=13) +----- Forum: GRAPHS AND NETWORKS (https://mklab.gr/forumdisplay.php?fid=202) +----- Thread: Network theory (/showthread.php?tid=2195) |
Network theory - mklabgr - 09-25-2026 Network theory is a branch of graph theory, mathematics, computer science, and network science that studies systems represented as nodes (vertices) connected by edges (links). The connections can be symmetric or asymmetric, and both nodes and edges can have attributes such as weights, directions, or capacities. A network can therefore be represented mathematically as a graph $G=(V,E)$, where $V$ is the set of vertices and $E$ is the set of edges. The origins of network theory are often traced to Euler's solution of the Seven Bridges of Königsberg problem. A major part of network theory is network optimization: finding the most efficient way to move through or organize a network. Important problems include shortest paths, maximum flow, transportation, matching, assignment, routing, network location, and critical-path analysis. For example, in a weighted graph, the shortest-path problem seeks a path $P$ minimizing its total weight, $d(u,v)=\min_{P:u\rightarrow v}\sum_{e\in P}w(e)$. These problems connect graph theory with combinatorial optimization, algorithms, operations research, logistics, and computer science. Network analysis focuses on understanding the structure and importance of different parts of a network. One of the central ideas is centrality: determining which nodes are structurally important. Degree centrality measures the number of connections a node has, while betweenness centrality measures how frequently a node lies on shortest paths between other nodes. Closeness centrality measures how near a node is to the rest of the network, and eigenvector centrality gives greater importance to nodes connected to other important nodes. If $A$ is the adjacency matrix, eigenvector centrality can be expressed through $Ax=\lambda x$. These concepts are used in social networks, the Web, biological systems, transportation, telecommunications, and fraud detection. Modern network theory extends beyond static graphs. Spatial networks incorporate geographical location, while temporal networks explicitly model connections that change with time. Network theory is also used to study how information, diseases, rumors, financial shocks, and other phenomena spread through interconnected systems. In biological networks, for example, nodes can represent genes, proteins, or species; in social networks they can represent people or organizations; and in computer networks they can represent computers or websites. This makes network theory a powerful mathematical framework for studying complex systems in which relationships between objects are as important as the objects themselves. Key Takeaways
ARTICLE / PDF |
