What if you only see part of a network? - Printable Version +- MKLab (https://mklab.gr) +-- Forum: [INDEX] (https://mklab.gr/forumdisplay.php?fid=1) +--- Forum: MATHEMATICS (https://mklab.gr/forumdisplay.php?fid=3) +---- Forum: ARTICLES (https://mklab.gr/forumdisplay.php?fid=13) +----- Forum: GRAPHS AND NETWORKS (https://mklab.gr/forumdisplay.php?fid=202) +----- Thread: What if you only see part of a network? (/showthread.php?tid=2194) |
What if you only see part of a network? - mklabgr - 09-25-2026 The article from Tech Xplore, based on research at Leiden University, explores a fundamental problem in network science: how can we understand a network when we can observe only part of it? Networks appear everywhere, from friendship and internet connections to brain networks and international trade. Alessio Catanzaro developed mathematical methods for reconstructing incomplete networks. His key insight is that mathematically removing the unseen part of a network has an effect analogous to renormalization, where smaller components are combined into larger-scale units. This suggests that the visible portion of a network can contain information about its hidden structure. Catanzaro's work also leads to a surprisingly simple multi-scale network model, informally called the "pizza model." Rather than explicitly assuming that nodes belong to geographical or social communities, tightly connected groups can emerge naturally from the mathematical rules of the model. This is significant because real networks often display community structure even when those communities were not explicitly programmed into the model. Such ideas could potentially be useful for studying social networks, epidemiological transmission, biological systems, and large datasets. The second part of the article focuses on Francesca Giuffrida's work on a different but related question: when does an observed pattern represent a genuine relationship rather than random chance? A major difficulty is that "chance" itself can be mathematically defined in different ways, and different assumptions can lead to different statistical conclusions. Giuffrida developed statistical methods for choosing appropriate models when researchers compare competing explanations. Her research particularly examines e-values, an alternative framework for evaluating statistical evidence that can offer greater reliability and reproducibility than some traditional approaches. Giuffrida applied these ideas to brain-imaging data, where the methods helped distinguish connections between brain regions that were supported by the data from connections that could plausibly have appeared by chance. The broader message is that modern network science combines graph theory, statistical inference, probability and mathematical modeling to deal with two fundamental problems: hidden structure and false patterns. Together, the two research programs show how relatively abstract mathematical ideas can provide practical tools for understanding complex systems. Key takeaways
