Decades-old problem in classical geometry solved - Printable Version +- MKLab (https://mklab.gr) +-- Forum: [INDEX] (https://mklab.gr/forumdisplay.php?fid=1) +--- Forum: MATHEMATICS (https://mklab.gr/forumdisplay.php?fid=3) +---- Forum: ARTICLES (https://mklab.gr/forumdisplay.php?fid=13) +----- Forum: GEOMETRY (https://mklab.gr/forumdisplay.php?fid=150) +----- Thread: Decades-old problem in classical geometry solved (/showthread.php?tid=2183) |
Decades-old problem in classical geometry solved - mklabgr - 09-25-2026 A team of mathematicians from the Technical University of Munich, Technical University of Berlin, and North Carolina State University has produced the first concrete example of a compact Bonnet pair. The result resolves a problem that had remained open for decades in classical differential geometry. The researchers constructed two globally different, closed torus-shaped surfaces that nevertheless have exactly the same intrinsic metric and the same mean curvature. The underlying question goes back to the French mathematician Pierre Ossian Bonnet. A traditional principle suggested that if one knows the metric of a surface—essentially, all information about distances measured along it—and its mean curvature at every point, then the surface should be uniquely determined. In mathematical terms, the metric describes the intrinsic geometry, while the mean curvature describes how the surface bends in three-dimensional space. The new result demonstrates that these data can, in certain compact cases, fail to determine a unique global shape. The distinction between local and global geometry is central. The two tori have the same intrinsic distances and the same curvature information, so measurements made locally cannot distinguish them. Yet their global structures are different: they represent two distinct embeddings of essentially the same geometric data. Previously, counterexamples were known for non-compact surfaces, but for compact surfaces the situation was much more restrictive. In particular, for tori mathematicians knew that a given metric and mean curvature could correspond to at most two surfaces—but nobody had actually exhibited such a pair. The work, by Alexander I. Bobenko, Tim Hoffmann and Alexander O. Sageman-Furnas, was published as Compact Bonnet Pairs: Isometric Tori with the Same Curvatures in Publications Mathématiques de l'IHÉS (2025). The result was subsequently recognized with the 2026 Frontiers of Science Award. Conceptually, the discovery is important because it shows that even very detailed local geometric information—metric plus curvature—may not encode the complete global geometry of a closed surface. Key mathematical ideas
