Virtual facet patterns and diamond design - Printable Version
+----- Forum: ARTS AND VISUALIZATION (https://mklab.gr/forumdisplay.php?fid=155)
+----- Thread: Virtual facet patterns and diamond design (/showthread.php?tid=2042)
Virtual facet patterns and diamond design - mklabgr - 09-18-2026
The article “Virtual facet patterns and diamond design” by J. Conant and colleagues, published in the Journal of Mathematics and the Arts in September 2026, develops a mathematical framework for explaining why diamonds look the way they do. The central concept is the virtual facet (VF): although a diamond may have a relatively simple physical faceting structure, light repeatedly refracts and reflects inside it, dividing the observer’s visual field into polygons corresponding to different light paths.
The authors formally define virtual facets in terms of their sequence of interactions with the diamond’s facets and prove that, under their primary-ray/orthographic model, these regions are convex polygons whose boundaries arise from the diamond’s physical edges. They use ray tracing and beam tracing to calculate these patterns and show how they relate to familiar visual phenomena such as brilliance, fire, scintillation, windowing, “arrows,” bow-ties and crushed ice.
A major contribution is going beyond simply counting or measuring virtual facets. The authors introduce measures such as visual influence, which accounts for a facet's area, shape and light-path length, and k-flectors, which classify virtual facets according to the number of internal reflections in their light paths. This provides a way to model the fact that large, shallow virtual facets are generally more visually important and easier to focus on than tiny facets associated with long, complicated paths—the latter often producing the “crushed ice” appearance.
The paper also shows that secondary and tertiary light rays, normally ignored in simplified models, can matter substantially under spot lighting and can contribute to sparkle and fire. Finally, the GIA team applies these mathematical tools together with an enumeration algorithm for symmetric polyhedra to design new diamond cuts, including the Jasmine, Poppy, Sunray, Blossom and Pinwheel designs. The broader goal is to turn mathematical analysis of virtual-facet patterns into a foundation for a future GIA grading system for fancy-shaped diamonds.
