Nonlinear Dynamics and Chaos [Steven Strogatz] - Printable Version
+---- Forum: COURSES & LECTURES (https://mklab.gr/forumdisplay.php?fid=37)
+----- Forum: COURSES (https://mklab.gr/forumdisplay.php?fid=58)
+----- Thread: Nonlinear Dynamics and Chaos [Steven Strogatz] (/showthread.php?tid=2011)
Nonlinear Dynamics and Chaos [Steven Strogatz] - mklabgr - 09-15-2026
The playlist is Steven Strogatz’s Nonlinear Dynamics and Chaos lecture series, a university-level introduction to the mathematical theory of dynamical systems and chaos.It develops the basic language of dynamical systems, beginning with first-order differential equations and phase-line analysis, then moving to two-dimensional systems, phase planes, equilibrium points, stability, linearization, and bifurcations.
The lectures emphasize geometric intuition as well as analytical techniques, showing how differential equations can describe the evolution of physical, biological, and other real-world systems.
The later material develops the ideas that lead to nonlinear dynamics and chaos: limit cycles and oscillations, bifurcation phenomena, the Poincaré map, discrete dynamical systems, and chaotic behavior. A central theme is that relatively simple deterministic equations can generate surprisingly complicated long-term behavior, including sensitivity to initial conditions and apparently irregular trajectories.
Overall, the series provides a coherent mathematical pathway from ordinary differential equations to the modern concepts of stability, bifurcation, nonlinear behavior, and chaos, and corresponds closely to the topics covered in standard texts such as Strogatz's Nonlinear Dynamics and Chaos.
PLAYLIST
