Academic profession to see its work taken over by AI - Printable Version
+---- Forum: ARTICLES (https://mklab.gr/forumdisplay.php?fid=33)
+---- Thread: Academic profession to see its work taken over by AI (/showthread.php?tid=1966)
Academic profession to see its work taken over by AI - mklabgr - 09-14-2026
Source: The Washington Post
This is a summary/commentary on the original article.
The original article is available to subscribers at The Washington Post.
The article examines a growing concern among mathematicians: what happens to human mathematical research if AI becomes substantially better than humans at discovering and proving advanced mathematics? At an August 2026 summit hosted by OpenAI, around 40 mathematicians discussed this question. Daniel Litt presented a deliberately pessimistic scenario in which AI produces so much high-quality mathematics that human expertise eventually loses its value. Although he considers this extreme outcome unlikely, he argues that mathematicians need to adapt now.
The concern is particularly significant because AI is already producing results that appear to approach genuine research-level mathematics. OpenAI reported a result disproving the unit distance conjecture, while other AI-assisted work has produced new constructions in areas such as group theory and combinatorics. In one striking example, an Anthropic mathematician used Claude to obtain a result concerning perpendicular vectors in a 668-dimensional cube; another person prompted ChatGPT repeatedly to attack a network-flow hypothesis until it generated a counterexample.
However, the article emphasizes that AI-generated mathematics still creates serious problems of verification, exposition, and understanding. Traditional mathematics depends on researchers discussing ideas, checking proofs, publishing preprints, and eventually peer review. AI can generate enormous quantities of arguments much faster than humans can evaluate them. Formal systems such as Lean can help verify correctness, but their proofs can be extremely lengthy and difficult for humans to understand.
More than 3,000 mathematicians therefore signed the Leiden Declaration, calling for responsible AI use, proper verification, and clear citation of AI-generated results.
Importantly, the article does not portray AI as having already replaced mathematicians. Gábor Kun and Andreas Thom, whose earlier work was extended by an OpenAI result, described AI as clever and significant but emphasized that the new concepts emerged through interaction between humans and the AI. Similarly, mathematician Melanie Matchett Wood observed that leading models still struggle to identify and clearly explain the genuinely difficult parts of an argument.
The article ultimately presents several possible futures rather than one inevitable outcome. Mathematics could become more like software engineering, with AI enabling large teams to attack problems; more like experimental physics, requiring enormous computational resources; or even like museum curation, where AI generates discoveries and humans decide which ones are meaningful. Another possibility is that mathematicians increasingly move toward AI safety. The central principle expressed by OpenAI's Sébastien Bubeck is that mathematics should remain valuable because humans learn and understand the mathematics produced by AI—not merely because AI can produce proofs.
Bottom line: The article's central message is not “AI has replaced mathematicians,” but rather “AI is beginning to change what mathematical research means.” The major challenge may shift from solving problems to deciding which problems matter, verifying machine-generated mathematics, extracting human-understandable concepts from it, and ensuring that mathematical understanding does not disappear behind automated proofs.
