The Drake equation - Printable Version +- MKLab (https://mklab.gr) +-- Forum: [INDEX] (https://mklab.gr/forumdisplay.php?fid=1) +--- Forum: MATHEMATICS (https://mklab.gr/forumdisplay.php?fid=3) +---- Forum: ARTICLES (https://mklab.gr/forumdisplay.php?fid=13) +----- Forum: EXPOSITION (https://mklab.gr/forumdisplay.php?fid=156) +----- Thread: The Drake equation (/showthread.php?tid=1921) |
The Drake equation - mklabgr - 09-09-2026 The Drake Equation Jørgen Veisdal’s article explains the Drake equation, proposed by astronomer Frank Drake in 1961 as a framework for estimating how many technologically advanced extraterrestrial civilizations might currently be detectable in the Milky Way. The equation is $N = R_* \times f_p \times n_e \times f_l \times f_i \times f_c \times L$, where $R_*$ is the rate of star formation, $f_p$ the fraction of stars with planets, $n_e$ the number of potentially habitable planets per planetary system, $f_l$ the fraction on which life develops, $f_i$ the fraction that develops intelligence, $f_c$ the fraction producing detectable communications, and $L$ the duration for which such civilizations remain detectable. The equation was never intended to give a precise answer; rather, Drake devised it to organize the major scientific uncertainties involved in the search for extraterrestrial intelligence. Early optimistic assumptions produced estimates ranging from roughly 20 to tens of millions of communicating civilizations, illustrating how sensitive the result is to the chosen parameters. Astronomical observations have since improved some of these estimates. We now know that planets appear to be extremely common, and studies using Kepler data have suggested that the Milky Way may contain billions of roughly Earth-sized planets in habitable zones. However, the biological and sociological factors—$f_l$, $f_i$, $f_c$, and especially $L$—remain largely speculative because Earth provides essentially our only example of life and technological civilization. Using more modern astronomical estimates while assigning intermediate values such as $0.5$ to the unknown factors, the article obtains an illustrative estimate of about 46 communicating extraterrestrial civilizations in the Milky Way. The author stresses that this number should not be interpreted as a scientific measurement; it mainly demonstrates how assumptions propagate through the Drake equation. The article concludes by connecting the Drake equation with the Fermi paradox: if potentially habitable planets are abundant and technological civilizations are reasonably common, why have we seen no convincing evidence of them? Given the age and enormous number of stars in the Galaxy, even relatively slow interstellar expansion might allow a civilization to spread across the Milky Way in a few million years. Thus the tension between large Drake-equation estimates and the absence of observable extraterrestrials leads to Fermi’s famous question: “Where is everybody?” Key takeaways:
ARTICLE / ARTICLE [PDF] |
