The New Definition of Software Engineering in the Age of AI - Printable Version
+--- Forum: COMPUTATIONS (https://mklab.gr/forumdisplay.php?fid=4)
+---- Forum: PROGRAMMING (https://mklab.gr/forumdisplay.php?fid=68)
+----- Forum: ARTICLES (https://mklab.gr/forumdisplay.php?fid=89)
+----- Thread: The New Definition of Software Engineering in the Age of AI (/showthread.php?tid=1876)
The New Definition of Software Engineering in the Age of AI - mklabgr - 09-07-2026
The article argues that AI is not eliminating software engineering so much as redefining it: routine coding, boilerplate, simple CRUD apps, and syntax-heavy work are increasingly automated, so the value of engineers is moving toward system design, architectural thinking, debugging, performance, security, reliability, and accountability. Instead of measuring skill by how much code someone can write, companies increasingly care about whether engineers can understand complex requirements, make sound technical decisions, anticipate failures and edge cases, and turn AI-generated code into maintainable production systems.
The author recommends strengthening computer-science fundamentals, building realistic systems rather than tutorial projects, becoming excellent at debugging, using AI as a fast assistant rather than blindly trusting it, and creating strong public proof of work through serious projects and open-source contributions. In this new model, code becomes more of an output of engineering judgment than the main skill itself: the modern engineer must understand what to build, why it matters, how it should be designed, and how AI can accelerate the process without replacing human responsibility
