Coding Skills That Matter in the Age of AI - Printable Version +- MKLab (https://mklab.gr) +-- Forum: [INDEX] (https://mklab.gr/forumdisplay.php?fid=1) +--- Forum: COMPUTATIONS (https://mklab.gr/forumdisplay.php?fid=4) +---- Forum: PROGRAMMING (https://mklab.gr/forumdisplay.php?fid=68) +----- Forum: ARTICLES (https://mklab.gr/forumdisplay.php?fid=89) +----- Thread: Coding Skills That Matter in the Age of AI (/showthread.php?tid=1811) |
Coding Skills That Matter in the Age of AI - mklabgr - 09-03-2026 Coding Skills That Matter in the Age of AI — Brilliant Brilliant argues that AI is making the mechanical act of writing code increasingly cheap, so the most valuable programming skills are shifting away from simply knowing syntax. The developer’s role increasingly becomes deciding what should be built, how it should be designed, how AI should be directed, and how to determine whether the resulting software is actually correct. Brilliant organizes these abilities around seven areas: Taste, Incrementality, Specification & Design, Build, Verify, Security, and Abstraction. A central idea is that developers should work in small, understandable, verifiable increments. AI can generate code much faster than humans can review or understand it, creating what Brilliant calls comprehension debt: software may appear to work while nobody fully understands its assumptions, dependencies, or failure modes. The solution is to build thin end-to-end pieces, test risky assumptions early, use version control, keep changes reversible, and make sure each increment can be explained before moving on. The biggest change comes in the traditional development loop of specify → build → verify. As AI performs more of the build stage, Brilliant expects human expertise to concentrate increasingly on specification and verification. Developers need to define observable success criteria, design good data models and interfaces, decompose systems into independent components, understand dependencies and constraints, and then rigorously test AI-generated work. Brilliant therefore portrays the future programmer less as someone who types thousands of lines of code and more as a software architect, problem solver, reviewer, and director of AI systems. Key takeaways
Overall: Brilliant's thesis is compelling: AI probably does not eliminate the need to understand programming. Instead, it moves expertise one level higher—from “Can you write this code?” toward “Can you design the right system, instruct AI to build it, understand what it produced, and prove that it works?” ARTICLE |
