Advanced Techniques for Research with ChatGPT - Printable Version
+----- Forum: AI AND TECHNOLOGY (https://mklab.gr/forumdisplay.php?fid=158)
+----- Thread: Advanced Techniques for Research with ChatGPT (/showthread.php?tid=1746)
Advanced Techniques for Research with ChatGPT - mklabgr - 08-29-2026
The article explains how ChatGPT can function as a research assistant across several stages of a research project, particularly for data analysis, interpretation, literature reviews, and identifying research gaps. One example uses customer-satisfaction survey data to show how ChatGPT can calculate or explain descriptive statistics such as the mean, median, mode, ranges, and frequencies, and then help interpret patterns in the results. The author stresses that good results depend heavily on well-structured prompts containing sufficient context and clearly defined questions. Researchers should also avoid leading or biased prompts, because biased inputs can produce misleading conclusions.
A second major application is the literature-review process. ChatGPT can provide an initial overview of a research field, suggest influential literature, summarize major problems, and propose possible research gaps. In the article's renewable-energy example, the model identifies issues such as grid stability, energy storage, grid management, regulation, technological innovation, and system integration. These suggestions can help researchers formulate research questions and decide which topics deserve deeper investigation. However, the article repeatedly warns that ChatGPT's answers must be verified against authoritative sources and academic databases, since an AI model can provide inaccurate, outdated, or fabricated information.
The article also provides reusable prompts for generating research ideas, choosing methodologies and data-collection techniques, developing introductions and thesis statements, proofreading papers, and generating synthetic datasets. Its central message is that AI can substantially reduce routine research work, but it should augment rather than replace human expertise. The researcher remains responsible for evaluating evidence, checking sources, recognizing bias, and ensuring the accuracy and ethics of the final work. One detail is now dated: the article was published in July 2023 and refers to ChatGPT having a September 2021 knowledge cutoff. That specific limitation no longer describes current ChatGPT systems, although the broader advice to verify sources remains important.
  • Use ChatGPT as an assistant, not as an authoritative source.
  • Give it specific questions, context, data, and desired outputs rather than vague prompts.
  • It is particularly useful for exploratory data analysis, brainstorming, literature mapping, research-gap identification, editing, and methodology planning.
  • Verify citations, statistics, claims, and literature independently, especially when producing academic work.
