Algorithms and Programs: An AI-Assisted Approach [by Eric Braude] - Printable Version
+---- Forum: BOOKS (https://mklab.gr/forumdisplay.php?fid=32)
+----- Forum: NEW PUBLICATIONS (https://mklab.gr/forumdisplay.php?fid=110)
+----- Thread: Algorithms and Programs: An AI-Assisted Approach [by Eric Braude] (/showthread.php?tid=1709)
Algorithms and Programs: An AI-Assisted Approach [by Eric Braude] - mklabgr - 08-20-2026
Author: Eric Braude
Publication date: August 2026
Publisher: Addison-Wesley Professional
Length: 144 pages
Level: Intermediate
ISBN: 9780135887622
Algorithms and Programs: An AI-Assisted Approach presents classical algorithm design from a modern software-development perspective, with particular emphasis on how AI tools can assist in specifying, designing, implementing, testing, and verifying algorithms. Braude argues that simply expressing an algorithm as code or conventional pseudocode often hides its underlying logic. Instead, he advocates creating structured algorithm outlines that describe the outcomes each part of the algorithm is intended to achieve. These outlines form an intermediate layer between the mathematical idea and the final program, making correctness, invariants, and complexity easier to reason about.
The first part of the book develops this methodology through problem specification, functions and classes, algorithm decomposition, complexity analysis, invariants, and systematic algorithm construction. AI is treated as a development assistant: it can help formulate requirements, generate or implement algorithmic outlines, test code, and inspect whether the resulting implementation actually satisfies the intended conditions. The emphasis is therefore not on letting AI simply “write the program,” but on giving it a sufficiently precise specification so that its output can be checked and reasoned about
The later chapters apply this framework to the standard core of an algorithms course: divide-and-conquer, sorting, dynamic programming, greedy algorithms, minimum spanning trees, and shortest-path algorithms. Examples include binary search, mergesort, quicksort, heapsort, radix sort, rod cutting, longest common subsequence, Huffman coding, Prim's and Kruskal's algorithms, Bellman–Ford, and Dijkstra's algorithm. Thus, although AI is prominent in the title, the book is fundamentally an algorithms text that attempts to rethink how algorithms should be designed and explained in the era of generative AI.
  • Specification before coding: clearly state what a function or algorithm must accomplish before attempting to implement it.
  • Algorithm outlines rather than raw pseudocode: Braude proposes describing algorithms through intended intermediate outcomes, making correctness and invariants more transparent.
  • AI as a collaborator, not an oracle: AI can generate and inspect implementations, but reliable development still requires precise specifications and verification.
  • Traditional algorithmic thinking remains essential: complexity analysis, divide-and-conquer, dynamic programming, greedy methods, graph algorithms, and invariants remain central even when AI writes part of the code.
BOOK
