Staircase paradox - Printable Version
+----- Thread: Staircase paradox (/showthread.php?tid=1301)
Staircase paradox - mklabgr - 07-25-2026
[Image: GU8wd.jpg]
Staircase paradox
The Staircase Paradox is a classic example in mathematical analysis showing that the limit of a sequence of curves does not necessarily preserve their length. Imagine approximating the diagonal of a unit square with an increasingly fine "staircase" made of horizontal and vertical segments. As the steps become smaller, the staircase visually converges to the diagonal, yet its total length always remains 2, while the diagonal itself has length √2 ≈ 1.414. This seemingly contradictory result arises because although the staircase converges to the diagonal in shape (uniform convergence), its geometric length does not converge to the diagonal's length.
The paradox demonstrates that arc length is not a continuous property under all types of convergence and highlights the importance of carefully defining limits in calculus and geometry. It also explains why simply approximating curves with arbitrary polygonal paths can produce incorrect measurements. Beyond pure mathematics, the Staircase Paradox has practical applications in digital geometry and computer vision, where estimating the perimeter of pixelated objects requires more sophisticated techniques than merely summing pixel edges. The paradox has a higher-dimensional analogue known as the Schwarz lantern, and it is closely related to concepts such as the coastline paradox, illustrating how intuition about limits can sometimes be misleading.
