Integer complexity - Printable Version +- MKLab (https://mklab.gr) +-- Forum: [INDEX] (https://mklab.gr/forumdisplay.php?fid=1) +--- Forum: MATHEMATICS (https://mklab.gr/forumdisplay.php?fid=3) +---- Forum: ARTICLES (https://mklab.gr/forumdisplay.php?fid=13) +----- Forum: NUMBER THEORY (https://mklab.gr/forumdisplay.php?fid=148) +----- Thread: Integer complexity (/showthread.php?tid=1206) |
Integer complexity - mklabgr - 07-19-2026 Integer complexity Summary Integer complexity is a mathematical concept that measures how efficiently a positive integer can be built using only the number $1$ and basic arithmetic operations such as addition and multiplication. The complexity of an integer is defined as the smallest number of ones needed to create it; for example, the number $6$ has complexity $5$ because it can be written as ($6=(1+1)(1+1+1)$), requiring five ones. This idea connects number theory, combinatorics, and computational mathematics because it explores the most economical representations of numbers. Researchers study patterns in integer complexity, including how complexity grows with the size of numbers, the relationship between complexity and digital properties, and the search for optimal constructions. Although simple to define, integer complexity contains many open problems, such as understanding the exact complexity of large numbers and determining whether certain inequalities and growth patterns always hold. It provides a fascinating way to investigate the hidden structure and efficiency of arithmetic expressions. ARTICLE |
