Gelfond's constant - Printable Version +- MKLab (https://mklab.gr) +-- Forum: [INDEX] (https://mklab.gr/forumdisplay.php?fid=1) +--- Forum: MATHEMATICS (https://mklab.gr/forumdisplay.php?fid=3) +---- Forum: ARTICLES (https://mklab.gr/forumdisplay.php?fid=13) +----- Forum: CALCULUS AND ANALYSIS (https://mklab.gr/forumdisplay.php?fid=149) +----- Thread: Gelfond's constant (/showthread.php?tid=1131) |
Gelfond's constant - mklabgr - 07-15-2026 Gelfond's constant Summary Gelfond's constant is a fascinating number in mathematics defined as ($e^\pi$), the result of raising the famous Euler number ($e$) to the power of ($\pi$). It is approximately equal to $23.140692632779...$, and it appears in several areas of mathematics despite having no simple everyday interpretation. The constant is named after the mathematician Alexander Gelfond, who proved in 1934 that it is a transcendental number, meaning it is not a solution of any polynomial equation with rational coefficients. This discovery was part of Gelfond's work on transcendental numbers and solved a major problem known as Hilbert's seventh problem. Although (e^\pi) looks like a simple combination of two fundamental constants, its properties are surprisingly deep and connect different branches of mathematics. Gelfond's constant is a beautiful example of how familiar mathematical objects can combine to create numbers with extraordinary and unexpected characteristics. ARTICLE |
