Carpenter's rule problem - Printable Version
+----- Thread: Carpenter's rule problem (/showthread.php?tid=1116)
Carpenter's rule problem - mklabgr - 07-14-2026
The Carpenter’s Rule Problem is a famous problem in computational geometry that explores whether any simple polygon can be continuously transformed into a convex polygon without allowing its edges to cross. The problem is inspired by the movement of a folding carpenter’s rule, where hinged segments can be repositioned while preserving their lengths. Mathematicians asked whether every possible “unfolded” shape made from connected line segments could always be straightened into a convex form through a sequence of continuous motions.
The problem was solved positively in the early 2000s by Robert Connelly, Erik Demaine, and Günter Rote, who proved that every simple polygon has a collision-free “convexification” motion. Their work introduced important techniques in rigidity theory, geometric transformations, and computational geometry, showing that flexible structures can often be manipulated in predictable ways.
The Carpenter’s Rule Problem is significant because it connects abstract mathematical theory with practical applications in robotics, animation, mechanical design, and the study of flexible structures, demonstrating how geometry can describe complex motions in the real world.
