Nested radical - Printable Version
+----- Forum: NUMBER THEORY (https://mklab.gr/forumdisplay.php?fid=148)
+----- Thread: Nested radical (/showthread.php?tid=1062)
Nested radical - mklabgr - 07-11-2026
Nested radical
Nested square roots are one of the most intriguing forms of nested radicals, where a square root contains another square root, either a finite number of times or continuing indefinitely. The mathematics of denesting square roots asks when these seemingly complicated expressions can be rewritten in a simpler form without nested radicals. For expressions involving two nested square roots, mathematicians have established a complete criterion that determines exactly when such simplification is possible, while more general cases require sophisticated tools from field theory and Galois theory.
 A major breakthrough came with Susan Landau’s algorithm, which provides a systematic method for deciding whether many classes of nested radicals can be denested, although the procedure becomes computationally demanding for deeply nested expressions. Nested radicals also appear naturally in algebra, particularly in the formulas for solving cubic equations, where they sometimes cannot be simplified further because of fundamental algebraic limitations.
The article also explores infinitely nested square roots, which often converge to well-defined values despite their endless structure. A classic example is $(\sqrt{2+\sqrt{2+\sqrt{2+\cdots}}})$, whose value is found by recognizing that the entire infinite expression repeats inside itself, leading to a simple algebraic equation.
More general formulas describe the limits of similar infinite radicals, and special families of nested square roots of 2 are closely connected to trigonometric functions such as sine and cosine. These elegant relationships demonstrate how nested radicals link algebra, geometry, and analysis, illustrating how deceptively complex expressions can reveal deep mathematical structure and surprising connections across different areas of mathematics.
